Indycars
I don't have the trailer connected right now so I can't check, but I see in the manual where it has a three "Brake Boost" setting. I will need to try setting that higher.It all depended on how the trailer break controller was set. Mine had a manual lever to use if needed.
Thanks for the input !
Yes it was good to see you and everyone else..... finally !It was good to see you in Tennessee the other night......Way to much Fun......
You don't think it needs to be locked in place somehow to keep it from bouncing out of the box while the trailer is in motion ???A small box (about 1/2 the size of extinguisher height) bolted to the wall makes quick access.
Rewiring the whole trailer is in my plans some day!A lot of brake issues come from undersize wiring.
