2old2fast
After doing some reading here's what I've found ; acc. pump nozzles are pressed into the carb body [non replaceable] acc pump linkage can not be altered , Your problem is most likely mis adjusted sec. carb flap adj [not closing completely]Google " THECARBURETORSHOPP LLC for some good reading......that's a "smallish" cam so should be easy to tune....AGAIN , call the guy who built the carbs , if anyone knows, he does...
