MustangMike67fb
I know this type of question is drawn out like crazy and have read many pieces of info on this. However I think my situation is a bit different.
I have been mocking up my frame with major components and notice how things are sitting.
It appears that my engine will be sitting lower than my rear end. If I am leveling the engine by the carb, I will have approx a 3* negative angle. This is bad since the rear is (maybe 5 inches higher as it sits on its wheels)
Do I need to raise my engine (maybe 5 inches) to get level with the rear end or do I raise my trans so it has a positive 3* angle and have my rear at a neg 3* angle????
This seems backwards but I dont see any difference other than engine/ trans not being at a good angle for operation ( fuel/ oil levels)
I will have to measure the difference to be more accurate when I get home but I know that the rear is definitely higher.
Thank you!!
Thank you!!
