I see you're now onto what PotvinGuy was saying to you.
I want to be sure I am correct in what I am saying. From the general gist of this topic, it seems you have been working at trying to get the car more responsive off idle. Yes?
The key word in that statement is 'idle'.
Take a look at your cam card. Look at the RPM range for the cam. 2,800 - 6,100 RPM. And you're trying to get the car to respond off idle?
Take a look at Weiand's recommendations on that intake manifold. 2,500 RPM and up. And you're trying to get the car to respond off idle?
You want things to work better? Then use the components as they were designed to be used. Get the car to the local dragstrip. Stage the car, get the motor all the way up against the converter and then let her eat. Those are race pieces, so drive the car like a race car. How well does the car respond in those conditions?
We used to build a lot of short-track IMCA Modified motors. We used a custom, mechanical tappet cam that didn't have nearly that much duration or valve lift. The LSA numbers were a lot lower, but we accepted the fact they were race cams and lived with it. Add the best part of 12.5:1 compression, Brodix Track 1 heads, HV-1000 intakes and 750 carbs. The guys loved them, because they would step out front on re-starts and pull all the way through 7,200 RPM (we used billet cam cores so we could run heavier springs). These were race motors, not street rod motors. They were outright slobbery up through about 2,600 - 2,700 RPM, but stand on it from there and they would rip your head off.
You're trying to use a bigger cam profile than that, along with a tunnel ram intake and two carbs no less, and make the combination transition well off idle? Hello??
You've never mentioned cylinder head chamber volume, but I'm betting it is way too high. The LSA on the cam will help a bit, but unless you're running a 305 casting or an aftermarket casting with similar volume numbers, your cylinder pressure is too low. Which will also contribute to a motor acting lazy.
When Comp Cams and Weiand are telling you to use their pieces at 2,800 RPM and higher, what are you hoping to find, nearly 2,000 RPM below that number? Whatever you're looking for, I can tell you it isn't there.
If you are married to what you have, then it's time to start looking into adding a band-aid or two. Was your cam gear drilled to accept bushings to change cam timing? If not, you'll need to drill it. Roll the cam up with a 2° bushing and check your piston to valve clearance. If you still have clearance, button her up and give it a try. Skip checking clearances at your own peril, because I'm betting you're already on the too-tight side of things.
That should help, considerably.
Get a couple fresh carb base gaskets and a piece of aluminum shim stock. Use your gaskets to cut the outline on your shim stock. Lift the back carb, drop on a fresh gasket, your new block-off and another fresh gasket. Bolt the carb back down. Give things another try. Rermember, you're back to just one carb, so your idle mixture settings are going to be in left field. How does that work for you?
If that works well, it's time to ditch that dual 4BBL top and replace it with a single 4BBL top. This will require a lot of money and a considerable amount of patience on your part, but take the intake base and single 4BBL top to a professional cylinder head porting shop. Explain what you're trying to use the intake on. Do your best to endure the laughter and explain why you need to use that particular intake. They can weld up the runners and stuff the plenum, to get them to a more reasonable volume. You are going to spend something in the vicinity of 8 times what the intake is actually worth, so be prepared for the expense to be high. Once everything is finished, bolt a 750 CFM vacuum secondary carb on top. You will want a selection of accelerator pump cams and squirters and a lot of spare time, but you'll likely be surprised at what you will be able to achieve.
You could find some improvement with a set of properly-built headers, but they will not come cheap. If something in the $2K range is within your budget, then that is another place to look. They will be designed to work, not to look pretty, so be forewarned. This would be the last resort step, in my not-so-humble opinion, so if you're not willing to spend time and money on the other suggestions, I wouldn't get too fussed over this one.
See? Playing with idle mixture screws and a timing light are not going to effect the kinds of changes you are hoping to find. If you want a lot of off idle throttle response, you are going to have to give the carbs a lot stronger signal than you are now. And it's not going to happen with that camshaft and intake manifold.
