By "strong enough" I assume you mean will they carry the weight..? Yes. In fact, the ones I have may be a little too stiff. The good news is leaf spring load rates can be adjusted by adding or deleting leaves.
As for the rubber torsion system - the only adjustability of that system would be through the durometer hardness of the rubber sleeves. The real problem is, those systems usually have all the steel or aluminum parts fabricated and assembled, then the rubber is cast in place and the whole assembly goes into an oven to have the rubber vulcanized. I don't know how you would do that on a street rod chassis. Welding on existing rubber torsion tubes that are pre-fabricated destroys the rubber inside and alters the spring rate. It's an interesting concept, but difficult to achieve.
