My knee replacement operation has been put off, so I'm starting my C-cab build early.....for the body I plan to mock up a steel skeleton using 1" x 1" rhs then covering that with the thinnest plywood I can find, when I have the right shape I will fibreglass over it. I know there is a different expansion rate between the three materials and fibreglass dirrect to metal on seen areas is a no no, because of the shrinkage difference between the two, but I think the plywood sandwiched between them will stop any shrinkage/expansion marks. Can someone tell me what thickness plywood would have to be used so that there would be no problems....as I said I want to use the thinnest available as there is a number of curves in my plan for the body
