Sounds neat, any pictures of such a set up?Watts link will make the front end real busy. A friend of mine had a vertical channel on the frame and a bearing on a shaft welded to the axle that rode up and down inside the channel. that was the cleanest front locator I ever saw, besides the dead perch.
Are you using cross steering or using a ford type pushing front to back? If front to back no panard bar is needed. Cross steering needs a panard bar.
Terry
Ah, the Watts linkage. I regard unique suspensions like the "complications" of fine watches; engineering works of art. Here's one, with the pivot on the axle:
I too have a tube axle (Speedway 4-bar with Panhard) and R&P. I designed this variation on the Watts:
It's called a Mumford linkage, and is often found on the rear of sports cars. It has some advantages in that arena, but I like it because the links are parallel to the ground and it would make people scratch their head. Some fabrication required, but you would have the only one.
I was going to do it on my car, but have decided to split the axle instead, eliminating the need for any locator mechanism. It was a close call, but so many folks told me the split axle wouldn't work that I have to try it.
It could be a unisteer?In his first post he stated that he intended to use a rack and pinion set up.
Unisteer? Bah, 'tis but half a proper R&P!It could be a unisteer?
