I have the same kind of tank, though not exposed. I cut a hole to the right of the filler neck to mount a "universal" fuel gauge sending unit on top of the tank. I used a rubber gasket to seal up the hole, and since it's on top of the tank, above the fuel level, there is no leakage. I wired it to the fuel gauge on the dash and it works fine for me.
(PS - I had to bend the mounting flange slightly to match the curvature of the tank.)
View attachment 24914View attachment 24915
Thanks a ton. This is a really cool idea.
The float follows the fuel level regardless of the tank shape. What you do need to be aware of is the indicated fuel level drops more quickly near the top/bottom of the tank. When my fuel level reaches 1/4 tank indicated, I start looking for a gas station!I’m curious as to how a gas gauge works in a round tank. I would think the only accurate reading would be half full. Anything above or below 1/2 would not be accurate.
Where do I find something like that? or what is it called so I can hunt it down?Another option, if you don’t want to cut/drill the top of your tank, is a gas cap with the float and gauge built in. You won’t be about to see your fuel level without looking over your shoulder but you would not need to make any modifications. The caps come in different lengths. You would need to make sure it fit your tank, otherwise it is screw on and go.
Thanks, I'll give it a shot
Thanks, I'll give it a shot![]()
So, in researching that part, I found out it's a screw on cap and not a twist on. I'm trying to find a twist on cap instead. Let me know if you happen to come across one, that'd be awesome.
