23 T 4sp
I had this Holley regulator on top of the motor near the thermostat housing. It was opening up right
after shutdown. The gauge near the carb would be
3.5 running then 6-7 when stopped. Edelbrock carb
with 1/2 “ wood spacer. The fuel pump is rated at 7 psi. Thinking about moving it to position in pictures. 3” from the header pipe.
Is this to close ?
There will be a small bracket to the head to hold it in position.
This is the second regulator I tried in the original
position.
Is this to close ?
position.
