terrymac
I'm having trouble with fuel gravity bleeding and flooding the engine to the point it will hydro lock if left with the shut off on over night. At first I thought the floats were too high and set them down, seemed to help it run better but it's still running rich. I pulled the needle valves and cleaned them. I again thought I had it resolved. Thought maybe I missed some dirt on the needle valve seats so turned the fuel off and run it out. Thinking this would flush the needle valves just in case. It was like a gyser fuel everywhere when I restarted with the fuel turned back on. I'm stumped, I would have thought the needle valves would hold off gravity
Terry
Opps ... I'm running 2 500 cfm eldebrock carbs with manual chokes. These were new from Speedway
			Terry
		 I am going to check my fuel pressure over the weekend just in case and go from there. He did say that it wasn't uncommon that mechanical pumps get up over 10 lbs. I've  never run into high pressure with a stock pump before but there is always a first I guess.
