fuse block for my tub
23tub
Car currently has an ENOS customs fuse block that has issues. Probably not really the fault of the block (looks like it's gotten wet in the past). Anyone have a recommendation? This thing just rests under the driver's seat - no place to bolt vertically. Thanks.
Are you asking what you should replace it with? If so, and you just want to buy the fuse block itself, most marine supply and marine surplus stores carry them in various configurations. The most modern ones use ATC fuses instead of the old glass fuses. Maybe even places like Ron Francis or American Autowire sell blocks separately from their kits.
I have had two cars with all the wiring under the seat and they do get wet occasionally, but I put drain holes in the floor in that area and use marine components for the water resistance qualities.
This is the setup I had in my 23 modified:
