Gas pedal
oino
Could someone please take a pic. of under there dash where gas pedal is. I want to see how its bolted to the body, and how the cable is connected.
I'm using a Spirit body.
Thank you.
Thank you.
i have 3 pics but the files are to big to upload
Here is mine, easy to build used a spoon from the kitchen (dont tell my wife)i later powder coated it. I used a cable with alum. ferruls crimped to the carb. Also made a bulkhead tube as a slider through the firewall (lamp tube, cut down)
I use mid to late 70s GM cable and pedal asembly that bolt to the firewall with screws. Must have plywood support inside firewall, and just screw it to it. Cut hole in plywood large enough for cable lock to fit through and lock onto just the fibreglass part of the firewall. Cable comes from the outside and has a button that slides onto pedal arm. Attach other end to carb,may have to buy accy. buttons,pins,or balls from any Advance/AutoZone/parts houses if they don't come with the carb.
Where do you upload to? I thought photobucket automatically resized them smaller if they were too large. You can get a free program called irfanview to resize photos. I have used it for about 6 years and it has no type of adware or junk attached to it.
