i recently came across a good deal on a set of shark gauges.i have the electronic one touch speedo and the quad gauge set.i am using the original pulse generator in my 700 r4 trans and the wiring diagram only tells you to hook one wire from the speedo to one side of the pulse generator.where dose the other wire from the pulse generator go?hot or ground?i asume it should be ground but i want to make sure before i blow up my speedolol.thanks Dan
