Pure gas.org will help. Marina's and also small airports.....
Theres a stabil ethanol treatment in a small bottle that you can use for you small outdoor motors, ie, chain saws, weed-eaters, lawn tractors, etc. Jus last week, I filled up my old farm truck, it was spitting and popping, added 2 bottles of heet, was alot better, then added about 14 oz's of Isopropyl alcohol....ran fine then....
I'm wiring up a electric fuel pump and just before the fuel filter by the carb, I'm putting in a Y with a valve on one leg with a extended piece of hose there on the inner fender, so I can drain that crap off as needed.
I'm also adding a water block filter to my T, as the water is absorbed, it will shut the filter down. I'll just carry a couple of extra spin-on's in my little tool box. Also, adding water-in-fuel light, screws into the bottom of the screw on diesel filters thats mounted just ahead of my pump back by the fuel tank. I'm gonna do the same to the old farm truck.
They came on the 1st & 2nd Gen. Dodge Cummins trucks....
Just look up the classic cars and ethanol....interesting stuff. All the money they're throwing away to make us self sufficient fuelwise, is pouring gas on the ground. Loosing fuel economy, adding that crap, we have to burn more to do than same job because the fuel doesn't have the same BTU's. And these morons are using corn, that could be used to feed people, to make the fuel.
Its gonna get nothing but worse!!!!
