Building or I should say re-building a frame.
I had a narrow frame (22.5" outside) and it rubbed the bell housing, made it impossible to mount a brake master, etc.
I want to keep the front crossmember/spring perch, so I cut it off and I'm rebuilding the main rails.
I have two options:
1) Taper from 22.5 to 26.5 at the rear kickup which would be about 86" from the front crossmember
2) Taper from 22.5 to 26.5 at the FIREWALL, and then maintain a 26.5 rectangle from the firewall to the rear kickup. (37.5" of taper)
Which would you do ?
Dimensionally, I'm thinking of setting the centerline of the engine mount at 19.25" from the front crossmember, which will give me plenty of room for the vega box (cross steer).
I'm running a 23 body with a turtle deck. I was thinking of adding 4-6" in the cowl to give a little more foot room.
So that would put the bell housing at 35.25" from the back of the front crossmember. I'd run a 2" gap between the bell housing mating surface and the firewall.
So a typical 23 body is 42", add 6" for a firewall extension that puts the body at 85.5" from the back of the front crossmember. Then we do the rear kickup, and rear part of the frame. The turtle deck is 36".
I think this ends up being about 116" wheelbase car if my math is right.
Anyway. Feedback appreciated.
I have two options:
