Yeah, I already talked to him and he said he didn't have posts, only the frame.Have you tried RPM -- Ron Pope? He has the standard ones listed on his website.
I would check Speedway Motors and Spirit Industries:
.https://www.speedwaymotors.com/Search?query=windshield%20post&facet=GA_Market:T-Bucket*GA_SuperMarket:Street&gad_source=1&gclid=CjwKCAjwp4m0BhBAEiwAsdc4aL1uSgVTvBJmB2RUgu_tgWlWO9H_iytu6fmnnEUXJzn4iEcTteZbmxoCeEAQAvD_BwE
https://shop.spiritcars.com/windshields.html
All the ones I found were 30 degrees, I had to modify a 30 to get 15 degrees. Thirty degrees blocked the passenger door too much.I'm really trying to buy one that has a 15 degree angle if possible.
I'm guessing they are made offshore and there's a disruption in the supply chain. Too bad some domestic company can't cast them off a cloned mold. There seems to be no other substitute for T-buckets.I tried calling Speedway, but they were out of stock last I checked. Spirit is out of them too. So is CCR . . . . They must be in high demand right now.
Damn fine work.You can make your own with a bit of effort.
Just some stock steel and a bit of welding. You can angle the uprights to whatever you want.
G
View attachment 26023View attachment 26024View attachment 26025View attachment 26026View attachment 26027View attachment 26028View attachment 26029View attachment 26030
After brass powder coating... saves polishing. (frame done at the same time)
Great work, looks fantasticYou can make your own with a bit of effort.
G
Do you (CCR) have or in process of getting laid back ones?Polished!
