So I lost my key to my car and got no spare when I bought it. So i decided to just put in a new ignition. Replaced it with basically the same one. One of those universal dash ignitions that was like $10. So I wired it up the same as the old one. One of the problems is, its turning over in the run position rather than when you turn it all the way and it goes back to run position. Besides that, it wont start either. It is a 3 terminal ignition plus one in the center. So I switched the center wire to the empty battery terminal and once again the car turned over in the run position but it started up. but the starter is staying engaged the whole time its running til you shut it off. Any help? Never messed with this stuff before and figured just wire the new one , the same as the old
