EX JUNK
Moderator
Thanks Jim. Coming from you carries a lot of weight at my house. If I'm not mistaken I was thinking you might have single shear brackets on the rear chassis brackets. If so. I didn't mean to upset anyone's design cart. Big enough bolts can and do overcome bending forces. It's those big torque numbers and sticky tires that bend things. In the front end I feel these bending issues are more of a problem due to several things. Usually the bolt diameters are much smaller. The single batwing bracket is usually 3/8" thick allowing very little bearing load surface. Hole sizes are either laser/waterjet cut and sometimes are slightly over sized to the bolt OD. That allows the bolt to twist in the batwing which can egg shape that hole. I have always drilled holes just undersized then reamed to fit. Hairpin units are flexible by design and in my opinion should not be used to attach shocks to. I realize this might be over thinking or even anal thinking but I have been called and accused much worse. Just the industries I have hung out in over the last 50 years have inbred me into that world. And it really takes no more time to apply those standard to these cars then doing it quick and dirty. Looking at your car and your son's should be a must do by anyone starting out on their first build. Another one to study is Hotrod 46 and his roadster. I had a chance to really look it over at Spirit's Bucket Bash some years ago and it is well thought out and executed like yours. Hope this clears any mud in the water. Take care!
George
George, here are a couple of shots showing the brackets on my car. I use rod ends mounted with double shear brackets. The front is a four bar setup and the rear is an adjustable four link setup with a wishbone locator and all bolts are 1/2".
![](/proxy.php?image=http%3A%2F%2Fi374.photobucket.com%2Falbums%2Foo186%2Fexjunk%2Fchassis%2FIMG_0671_2.jpg&hash=a94197d7e46ac6fd0982f4b7d160abc1)
![](/proxy.php?image=http%3A%2F%2Fi374.photobucket.com%2Falbums%2Foo186%2Fexjunk%2Fchassis%2FIMG_0674_2.jpg&hash=aa751f1ce8ae70cfcdf053c08f254035)
