22rdstrguy
I was out eyeballing the Jag rear that I have and realizied that my frame is a little to wide 30 1/2 '' at the rear(originally was set up for coil sprung live axle)and the Jag shocks mounts are 29 5/8'' (frame is 1 1/2''x 3'')Quest.1) Can the Jag shocks be moved about 1'' either in or out without screwing up the geometry? Ques.2) Have any of you guys that run Jag diffs changed the shock angle and noticed any difference ie. "binding" ,etc.?
