hello to all! I have been working at my bucket for some time now. Mostly collecting parts. I got all the engine parts together and it's near ready to run on the dyno now so now I have the itch to get the rest of this thing together. I have a total performance frame set up for 4 inch drop. I don't have a four inch drop axle, only around 3 inch. so plan on running 14 inch in the front? Got the wheels and tires already. Any opinions on that? Bigest isue is getting it all together now. I opened the rear four link box from speedway only to find that the 4 bars are for the front instead of the back. I am working with them to see if we can rectify the issue at the moment. Looking for some pro street tires and 15 X 14 rear wheels right now. Rear end is an offset smooth back 9" ford. I need a set of coil overs but not sure what to get a the moment or I would order them Monday. Engine is a Dart block 347 ford with 10.5 cr Afr 205 heads. I got a bit carried away with it. 5000 to 6000 dollar moter ended up closer to $13,000. Well you only go around once. water under the bridge now. I am going to attach a few photos if I can of the current status of parts laid out. Please give me your thoughts, opinions and pointers. I need to get this frame together and got the itch now to do so
