mine will be over 10K but i'm like lumenAL. my 80 chevy truck i am around the 15K mark and or more and it isnt painted yet. $3500 in the rearend and suspension on it, but it shouldnt ever break .. started off to be a simple rearend narrowing and ladder bar set-up and cheap coil-overs, ended up being a full backbrace 9inch, 35 spline moser axles,full spool, 4:88 gears daytona pinion support, billet yokes, afco double adjustable shocks and wilwood disks..
my t-bucket is about the same. you can set budgets for yourself,but i'm like lumenal, if i'm there why not do it the best you can while your there..
I'm getting to be a tightwad though..so i'm going to stay somewhat budget minded on the T-bucket..and actually already have started it. sold the blower i had and building the engine with that and getting some gauges and already bought tunnelram setup.. just took the blower money and stretched it a little more is all..
I think you could keep budget minded, and doing almost all of it yourself you could do it easy, especially if you were building from scratch..i even built my drop tube axle though, building from scratch, i mean like taking Youngsters plans and going to the steel supplier and buying the steel and getting to work
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
i would think doing absolutely everything yourself and staying budget minded you could build a nice T for under $10k easy.. but buying a kit and building it from a kit, i dont see it happening...
