thebearded1
This may be a better question for the HAMB since it's older parts but the car isn't fully traditional so I thought i'd ask here. What bore size master cylinder is best for the following setup:
Front 1940 Ford drums, wheel cylinders have 1.00" diameter
Rear 1992 Jeep drums, wheel cylinders have .8125" diameter
I am currently using a master cylinder with 1.00" bore that was intended for a full drum setup.
I'm having issues getting decent braking. I bench bled the master cylinder, bled the full brake system, and adjusted the drums to have slight drag. Pedal ratio is 4.3:1 I also tried 5.2:1 and 6.5:1 and those did not feel any better. There are 10 psi residual valves installed as well.
![dec 5 08 (10) [640x480] (2015_11_13 11_07_31 UTC) (2021_01_12 08_56_11 UTC).JPG dec 5 08 (10) [640x480] (2015_11_13 11_07_31 UTC) (2021_01_12 08_56_11 UTC).JPG](https://tbucketeer.com/data/attachments/19/19898-c996dd10ed18fd287087506dfa117b30.jpg?hash=yZbdEO0Y_S)
![brake lines (3) [640x480] (2015_11_13 11_07_31 UTC) (2021_01_12 08_56_11 UTC).JPG brake lines (3) [640x480] (2015_11_13 11_07_31 UTC) (2021_01_12 08_56_11 UTC).JPG](https://tbucketeer.com/data/attachments/19/19899-782cfecff2654d31d14ac47eef173c28.jpg?hash=eCz-z_JlTT)
![brake pedal assbly (17) [640x480] (2015_11_13 11_07_31 UTC) (2021_01_12 08_56_11 UTC).JPG brake pedal assbly (17) [640x480] (2015_11_13 11_07_31 UTC) (2021_01_12 08_56_11 UTC).JPG](https://tbucketeer.com/data/attachments/19/19900-e303a945a2f83903d338a0e26dc6b9b2.jpg?hash=4wOpRaL4OQ)
