Master cylinders
Moderator
Is anyone using the old style "fruit jar" master cylinder on a disc/drum combo brake system?
I had one on my wife's T-bucket (drum - drum) for years. We changed to a Wilwood just for looks, the other one worked just fine.
I’m running a fruit jar master cylinder with drum brakes front and rear. I always worry about a brake line failure. Especially after 40 plus years on the road. I’m considering changing to a dual master and new brake lines. One of these days.
Not an expert but, the old single reservoir m/c was used on drum/drum only. That’s because disc brakes require more fluid movement… Most disc/drum use the duel reservoir because of that.
