Well, the process has begun. For the sake of ease (budget and build wise) I decided to go with either a small block Ford or Chevy with an automatic trans. After sifting through some possibilities, I landed on this '84 Camaro Z-28. 305, 700R4 and open rear.
It's a very rust free and fairly clean example. The engine is warmed over with a Eddy Performer cam, intake and carb. It starts right up and runs awesome. The trans was rebuilt 2000 miles ago and I assume the rear is good (haven't driven it). It has all new tires, brakes and front end parts. Also has a brand new fiberglass cowl induction hood. The best part is I got it for $1000. It's almost too nice to take apart. You don't see many around here that are this clean. But the fact is, they just aren't worth much. Sooo, she's comin' apart!
I can use the engine (needs to be cleaned and painted, but otherwise good), trans, rear and brakes directly from the car. I can sell the wheels & tires for maybe $200-$300. The hood is almost $600 new, so $300 shouldn't be a problem. I can probably part out a lot of the rest for an additional $500 or so. But, even if I just scrap it, I should be able to get $200 for it. So, all in all, I should be able to end up with the whole drive train for around $300. Not too bad so far...
I'll keep you posted on the progress....
