smokeyco75
Ron I will be calling you soon for the steering arms. Probably more stuff too.
I bought a 700R4 for $100.00. Been under water in may flood. Took it apart and rebuilding myself. Ordered a video and this is my first build. Might have 4 gears in reverse when done but im gonna try.I just picked up a th-350 transmission from Craigslist for $150.00. I was told it was rebuilt 10,000 miles ago and it has a higher stall converter but after the last thing I bought from Craigslist not being what I was told I am assuming that I merely have a rebuildable core. At least now I can finish mocking up the drive train after I finish the front suspension and steering.
Did that with a VW bus one time!! Four reverses and one forward. Tricky as hell to drive in reverse at 60 mph!! Last 700r4 I did had reverse only and no forward. BUMMER Valve in valvebody stuck.
Ya gotta love VW buses. I had one that I was using as a beater that died about 4 blocks from home...I drove it home powered by the starter motor in short bursts with a bit of gravity assist.
Only a guy with military connections would know how to [requisition and acquisition] such things!! Lot of that going on in Vietnam.
Love them flat 4's. I use to have a v.w. shop. Them little engines could sure turn it out.My connections were with a shop that built tubs, buggies and Formula Vee cars...,they kept a supply of the 8 volt aircraft batteries around...and the Bosch adjustable regulators. When they moved and I started doing custom Beetles on my own I just went to the local airport.
cheaper to build a T bucket now days.
My saind rails were hard to get in and out of, even with steering wheel removed. Bo duke that bad boy. Im gonna miss that rollcage. This T might have one before i quit.
