New member AZ old T-Bucket revival
Thanks. It's been a journey. Low buck fun is the plan. Still needs a lot of things cleaned up.
I see snicklefritz65 and a few others. Remember TFeverFred and SteelRebel from when they were active.
Currently trying to get a single 4 setup together to swap, a seatback and have a nail in a front tire. 😣
Sadly, TFeverFred passed a couple of years ago. Someone has purchased his bucket and is trying to finish it.
Yes, both have passed. I really miss Fred.
I didn't know that Black Dalia was still known, that's cool. Was Miss Behavin kept track of? I know he sold it cheap.
Another pic. I like how you can see thru the rad.
So, a bit of a description. Speedway front brakes, unknown (speedway?) front axle and hairpins.
Frame is an OE channel, boxed, cut, kicked. ZZ3 crate engine from 1989, it's been worked over, but no solid info from seller.
Hughes TH350 with a manual valve body, fairly low stall converter. 49-51 Olds rear axle with arms, diff is from a 52, 3:42 ratio.
Kia Rio rear coils (light) replaced the huge previous springs. 46-48 Plymouth rear shocks replaced the Harley coil-overs.
Ford F1 steering box, Chevy steering arm connecting to drag link. T wheel.
Modern vette style master on firewall, 5:1 ratio pedal, no booster. Takes a firm push!
Old body with card 'glassed in but faded to all white. Sanded down and primed, will need some work and blocking before paint. New floor, old stuff was a cobbled mess. Previous paint on body does not match paint on shell, lights or bed (all were Orange).
Basic headlights, 51 Chevy PU tail lights, Junk gauges and switches, flat dash.
Lots of improvements to come, but will not be a show rod.
I share your opinion to build a driver, not a trophy queen. The only thing I would be concerned with is that brake pedal ratio. Do you have plans to fix that? Mine is 7:1 and is an easy pedal push to stop.
Yeah, power ratio should be 4:1, manual 6:1. It's not ideal, but the fix is either move the pivot point up (it's already just under the cowl) or lengthen the pedal, which moves it from under the ball of my foot to under the arch. So it's just stiff. 20250429_125316.jpg
When I lived in Houston and single in the 1980s I saw a show queen. The inside of the body was painted the reverse of the outside, like you were looking thru a simi clear body.
Wish I had that much money on a whim!!!
A comparison of just after purchase and more recent.
The big chunks still to do are
single 4 bbl
Move alt down low on the right (needs W/P too)
Seat back
Windshield support rods (need front brackets welded up)
Long term is wiring, dash and gauges, body & paint, re plumb fuel and brakes, redo panhard and tidy up frame.
BTW, I know the interior is polarizing and different.
I wanted a 60s look and it couldn't be sewn or expensive.
For less than a hundred bucks in material and glue, I covered the interior. The seat bottom is a Mini sectioned and just sitting loose, wrapped in the same material. A bit of double sided tape and the column is covered.
The the couple shows it's attended, the ladies all comment on it.
It's the little things.
Plug wires tucked, radiator shell tilted forward to more closely match body, Body raised to level with bottom of frame, Bed mounted to match top of body, proper windshield, replacement of wheels, removal of scoop, Master cylinder was moved, but still under hood line, slightly shorter rear tire and softer spring in back.
Finally got moving on this. Still have to repair the cheap intake but have dry fitted things to see how it all fits.
I wanted to go this way due to the TR getting poor MPG, a low RPM stumble which is common for the design and wanting to make it look more 1960s than newer. Yes, the intake and carb are both newer, but a single 4 looks less 70s. The heads and valve covers aren't 60s either, along with the long water pump.
Still work to do and I'll miss the Peoria Rockabilly Bash show this year (coming up this weekend), but at least it's progress.
I bet you'll be a lot happier with the single 4 bbl setup. What it lacks in "cool factor" vs the tunnel ram it more than makes up for in driveability. Better gas mileage too! 👍
