iajjpop
On my t bucket, I have a vega box with a drag link to the passenger side wheel, then a tie rod in front of the axle to the wheel on drivers side wheel. I also have friction shocks. My problem is keeping the nut for adjesting the shock torqued to 60 ft lbs. It keeps comming loose,I have double nutted & put on locking nuts with a nylon lock [still comes loose]I have a flat washer under the nut. thank you..........
