I recently pulled the motor (302 Ford) out of my TP bucket to repair a leaky rear seal and take care of a few other issues. With the motor out, I could see a spot where the oil pan was rubbing on the crossmember, causing some noticible wear to both. How can I remedy this? I see three options
1. Shim the motor mounts enough for cleareance between pan and crossmember (3/8" or so maximum);
2. Put a dimple in the pan (least favorite-the contact spot is on a corner ane the new pan is chrome); or
3. Notch the crossmember slightly (cut notch out of tube, "box" with welded-in plate).
Which do you guys think is the best option? I'm very open to suggestions snd I want to do it "right"-no rubbing, no weakness, no damage (long or short term) to other parts, etc. Thanks in advance for sharing your wisdom!
