tfeverfred
The problem is that I'm not? Okay, I was going to go with an electric fan because of room. The upper radiator hose just won't let me run a conventional fan. Unless someone makes one that is 10" in diameter. So, for the last week or so, I have not run one at all. Now, a couple days ago, I let my car run up to 180 degrees to check the JB Weld repair I did on the radiator. It took a long tie for it to get up to that. Then today, I just got in from cruising around for about an hour and the temp never got above 160 degrees. I was even stuck in traffic for a while. Like about 15 minutes. It shot up to 170!
Now the temps in Houston have been mild for us, around 78 to 82 degrees. The radiator Tbucketlar sent me is the 4 core TP radiator. My motor is a stock 305 SBC. So, I guess my question is, is it possible to have a radiator that over powers the motor? Is it possible that this radiator may cool so good that I can get away without using a fan?
