@Golly is correct, that roll over valve is designed to be used at a fuel cell.
Here are a couple of things to think about. Just food for thought.
Whilst a roll over valve can be a handy thing on a race car, where a driver might be incapacitated or otherwise unable to get out of the wreckage, if a T-Bucket ends up on its top, where does that leave the driver and possible passenger/s? The 'top' of a T-Bucket is the driver's head. If a T-Bucket rolls, what chance does the driver have? At that point, a roll over valve suddenly represents just two more connections where leaks can develop. I know, it a rather macabre scenario, but reality is reality.
By a show of hands, how many of you make regular adjustments to your fuel pressure regulators? By 'regular', I mean every time you start the engine, once a week, once a month, or even once a year. OK, hands down. Now, by a show of hands, how many of you have mounted those wee, 1.5", oil-filled, fuel pressure gauges on a regulator or on a fuel log? OK, hands down. Now, by a show of hands, how many of that number are actually capable of monitoring fuel pressure on those gauges, whilst driving the car?
I recall someone (RPM, was it you?) had a panel mounted at the back of the motor with a couple of 2.625" gauges in it. Now, that would be the way to have a fuel pressure gauge set up, if you genuinely felt one was actually necessary. If you cannot actually read the gauge under normal driving conditions, what good is it?
One more time. By a show of hands, how many of you with a fuel pressure gauge you can actually read whilst driving the car actually carry, in the car, the necessary tools to adjust the regulator? If you don't have the ability to adjust the regulator, whilst on the road, then why worry about being able to read pressure, whilst on the road?
The majority of you are running over-kill fuel systems, in the first place. Put a test gauge on the regulator, set the pressure, lock the jam nut and forget about it. Next Spring, when you are getting the car out of Winter storage, hook up your test gauge, verify that nothing has changed and go drive the car.
