Screaming Metal
Only things attached to vacuum are PCV and I also added a power brake Master which is attached to the front carb vacuum port since no port on manifold exists (all new hose and fittings, tight)
Just because they're tight doesn't mean they're not leaking. All manifolds have places to screw nipples in and get vaccum....A vaccum tree is as close as your nearest parts house....
