AZCOWBO
Because I have a second front cross-member for my torsion-bar suspension (see Avitar), I had to make a bracket to raise the radiator, in order for my return hose to clear. Shoud I mount the bracket to frame on top of a couple of spring mounts, as shown in album photos, or mount the direct to frame and use one spring set-up on top of the bracket direct to radiator? Will either method require stabilizer arms, in addition to the support from the hoses?
Also, what is the best way to mount overflow reservoir, pop-rivets, screws???
