40ford
My wife's daily driver (2002 GMC Savana van, 5.7 liter V8, 62,730 miles bought new) started having a problem. Under load it would stutter, quiver, act like it was not getting fuel for a couple a seconds, service engine/check engine light would come on and then it would stop stuttering, light would go out and everything would be fine. It first did this about a month ago as we were going up Mount Eagle, not a good feeling, on our way to Murfreesboro, Tn to see our daughter, SIL and grandson. It has done it a couple of times since then. With my total knee replacement operations coming up Aug 5 my wife said find out what is wrong with her van. Took it to dealer yesterday for diagnosis. This is what it said - First fail 1328 miles ago, last fail 105 miles ago, 73 mph, 4 fails 162 passes. Most history misfires on cyls #3,4,5,6 & 7. Refer to #PIP0381 Bulletin on uphill/under load misfire due to TIGHT VALVE GUIDES. For this condition, reworking of cylinder heads/valve guides is recommended by manufacturer. Dealer said it would cost thousands of dollars to remove heads and send them to machine shop and get them fixed and reinstalled. They recommended adding a quart of Marvel Mystery Oil to crankcase and just keep driving it and that is what they did.
Tight valve guides??? All engines I have had valve guides wear and get loose not tight with age. VW bug did get tight if you did not adjust valves every 3000 miles. This makes me really want to go and buy another GM product after this. I have had Chevys, Buicks, Pontiacs, Olds, and GMCs, the Olds gave best service.
Question - I have seen where Ted talks about adding trany fluid to oil, on the Flathead Ford web pages people add MM Oil to every tank of gas to lube upper engine.
I would appreciate your thoughts, opinions, experiences, etc., on this. Thanks.
Ron A.
Ron A.
