I have a 1996 S-10 rear end from a junk yard. The outside casing/housing had gunk all over it and I assume it was from pinion seal leaking. So I'm thinking while it's not attached yet to the frame why not pull it apart and inspect all bearings & gears. The gears actually look good, but have not looked at bearings yet.
Question, If after inspection I only end up relacing the seals, do I need to check backlash since I'm re-using all spacers and bearings? :tnku:
