Rear spring
PostFab
Sooo.... I want to use an "A" rear buggy spring for my 27 Touring,looking at springs like Speedway sells , I have read they are too weak for a steel 4-door body.
Any thoughts or ideas ?
Thanks -
I had a look at the "high arch spring" specs, and it's rated at 345 lbs at 1 inch of compression. If that was a coil spring , it would be any amount stiff enough, so I'm pretty sure it would hold up a tourer using that info.
