Hello,I have a 27 spirit frame kit under my bucket and I want to get rid of the power brakes. The bucket is "finished" (are they really ever!!) so I am looking for options that doesn't move the MC because of the cut out in the body floor for it and doesn't require welding to the frame since its already powder coated. So here are a few of my ideas/questions:
- Fab up a spacer that bolts up to where the power booster is now and extend the push rod
- Fab up a bracket that bolts to the frame and extend the push rod (harder option I think because space limitations in getting a drill/tap around the body/frame)
- Leave the booster in and cap off the vacuum line. Is this safe? I only semi understand how power boosters works and don't really know what the internals look like (7" dual diaphram). I have a few holes in my brake pedal arm that will let me adjust the pedal ratio. As of now with the engine off, I can comfortable press the pedal so I dont think I will really need to change ratios.
- Of all the options, should I switch over to a "manual" master cyclinder? The one thats in there now is a steel corvette style, I think its a 1" bore and both reservoirs are equal size. I have disc on the front and drums on the rear.
Thanks,
Paul
