Brucer
ok i'm at a point i'm moving my engine and transmission back in the frame.
basicly moved my engine mounts back 2 inches .. it was 21-1/8 from the rear of the front crossmember, i moved the mounts back 2 inches, making it measure 23 1/8 from the front crossmember.
i'm also using a 700r4 transmission, this chassis was originally setup for a th350. so thats putting me having to move the transmission crossmember and also putting a drop in the transmission crossmember also..
this chassis was origianlly made from the ccr plans, and lengthened to 114" wheelbase, (center of front wheels to center of rear wheels, close anywyas)
The rear of the chassis was way up in the air, just to much rake for my taste, so ive dropped the rear down, and have set it on jack stands where i want it at ride height..
In lowering the chassis, i needed to move the engine mounts up so i have some ground clearance...so ive put the engine mounts level with the top of the frame, that will give me around 5 inches of clearance at the oilpan.
Now i'm getting ready to set the transmission/driveline angle... heres where my Question comes...
What angle do i need the block setting.. should it be level? should it be at a negative 3 degrees (transmission pointing down 3 degrees)? or should the top of the intake be level ???
