small update.......
Track-T
nothing large, installed a trans cooler.
trying to get things done before june...
Thanks Rex....Here's the fronts....
Sorry to say this as an after thought, but a trans cooler is totally unnecessary, now if you have a family sedan, loaded with Family and pulling a trailer over a hill in the desert, NOW you NEED a trans cooler... check Vetts, if you want to circulate the fluid, you can use a 4 foot piece of tubing and coil it around a piece of 2" pipe, run from one outlet to the other, but plugs work OK also. But seeing how you already have it in, nice job...
