Indycars
I had a Sonic Test done on my block and this is how the machinist described the process.
He checks every cylinder from top to bottom in one continuous motion. He does this at each of 4 positions; 12, 3, 9 and 9 o'clock. When he finds a location that is marginal, then he checks again on either side the thin location. For example on cylinder 1, he found at 6 o'clock 0.094" so he checked also at 5 & 7 o'clock and it was 0.220" and 0.229"
Below are the results. It certainly went below the 0.200" number, but it was always between adjacent cylinders and not on a thrust face. Cylinder number 4 has the single lowest number at 0.064", but on either side its 0.221" and 0.124". The lowest thrust face thickness was 0.220" on cylinder 8.
It never seems to be a black & white decision. I didn't think to ask at what height in the cylinder the thin locations were. And does the thrust even have much to do with the stress on the cylinder walls, is it more about the combustion pressures that are being exerted equally in every direction. The closer the thin section of the cylinder wall is to the top of the cylinder, the worse it would be for the engine......right??? Makes me wonder if I should have purchased a Dart SHP block for about $1500, I will have close to $900 in mine by the time it's done. I may have to go that route anyway, what do you all think, can I use my block for an engine that putting out 450-500 hp with 10:1 CPR, Max RPM=6400, street only with occasional blasts at full throttle ???
Any opinions are appreciated!
Rick Miller
Rick Miller
