joshuatronick
I ordered a new speedway 6 inch drop axle and thier spindles with the bushings already installed. My problem is I new to this and the pin will not go through the axle. Are these needing reamed? Also I found that the axle is not drilled for the locking pin. ???? There is a set screw dose it take place of the pins? Any help would be great!!!! Thanks
