westmichguy
Is there any reason that I couldn't or shouldn't cut the engine cross-member at the motor mounts? I would be leaving where the mounts are welded to the frame but eliminate the connecting part between the mounts. I have seen other buckets without this x-member, so why can't I? I am getting tired off lifting the body and the engine up high enough to remove the oil pan.
