Yes I have. I got a reverse valvebody (full manual) and a 3500 stall. IT IS FUN !!!!!!
It does not bang in there when you shift. But it is firm and RIGHT NOW. I would recommend it but you don't really need it. But if you have the power, blower, and 4.30 rear gear it is fun to have. And you definently burn more gas.
If you have M/T's you will definently have tire spin. Hoosiers are alittle better. I have always run dirttrackers and they HOOK. No spin hardly at all. And also much cheaper but not DOT. I have no problemms
T400 with manual valve body is fun to say the least, driving down the freeway or? at say 55 and you want to pass or someone in a late model car thinks these cars will not run, time to pull it back into low gear and start over from there hehe they are very surprised to say the least when you leave them sitting still... T Buckets are a Horse of a different color, but not really made for over 100 for long with a full windshield and or top... Drive safe at whatever speed turns you on... :hi:
I can just take off in drive and it depends on how hard I push the pedal as to how fast it goes before it shifts (stock first gear shift is 38 MPH) and it shifts smooth, well positive I should say but not jerky or wanting to spin the tires during regular take offs... :good: Full pedal is a different story... will hang in gear till you want it to shift...I guess what I am wondering is why the full manual over a modified valve body, which shifts like normal with faster engagement but can be used as full manual as you guys have described as well. Just a bit concerned with always having to shift.
Even with a modified TH400 with a shift kit I could not get it to shift when I waanted it to or to stay in 1st or 2nd long enough. Not until I went with the full manual valvebody does it shift when and immediately when I shift. I tried all sorts of mods to get it it to stay in gear longer and not shift early. I'm happy now and BOY is it fun.
