Brucer
the round front crossmember on the very front of most T's you see... Why is this round? is the only reason is that in the past they put the friction shocks on the end?
seems to me the way the T grille shell is, it would be alot cleaner if that front were rectangle tubing like the rest of the frame.. even with the spring behind setup it would be cleaner..
when i start in on my chassis i might look into doing this..
this looks cleaner to me
