Actually, I am running 3.08 gears ... I am told by th JAG expert here in Dallas, these are 100% European and very rare. He said they were used in the V12s and only for about two years. My unit is posi ... guess the V12s needed that.Outstanding. With the 2.88 your wallet may like the switch as well.
What transmission you running?
Hi, I am just starting to read about these projects, but I helped a buddy build a flat head T bucket a long time ago with straight axles.
Somewhere around post 40 in this thread there is a question about a 60 inch wide vs narrower rear ends, and the suggestion was to go with tires that sort of back filled the gap. Other than aesthetics, is there a reason to do this? I can think of a lot of reasons to want a wider setup.
I was also curious if anyone has ever attempted a 3 axle build - 2 rears, one front for sort of a van style T bucket. Yes I know it would be a bit of an odd duck, I am just curious.
Thanks
Harry
Thanks
Harry
Yea, hahaha....the scrubbing....like turning around to get back down the return lane at the strip....those spools in the rears don't like sharp turns.The reason its not done is that with a short wheelbase the 4 tires in back would make it hard to turn with all the leverage having another tire infront and would push the front end. If you could get it to turn the tires would squeal.
Has anyone used a Econoline axle from a van in there T bucket.
