rooster57
Well i have been having the wobbel from time to time and the toe in and out was set to 1/8 toe in . I was at an event today and one of the other guys said you sure got a lot of caster in your front end . My response was it is about 9 degrees. He said i bet its more than that. So when i got home i put my trusty angle finder and i had almost 20 degrees. ARG how did that happen so i dug my plans out and then it dawned on me when i built the axle i put 7-9 in it then then a year later when i did the assembly after powder coating i put 9 deg in it. So i had 18-20 deg caster. Today i removed 10 deg and it sure rides better and no wobbbbbel so far . What is your take on Caster and the wobbbbble problem.
