total performance brake pedal
wrenchbender63
ok I have crs can't remember s--- does any body know if a total performance 23t brake pedal has a bushing where the pedal goes through the frame mount cause I can't remember
There is no seperate bushing where the pedal goes through the chassis bracket(it is part of the pedal assembly). There should be a spacer between the pedal and Master Cylinder actuating rod.
Hope this helps.
Mike
