OINO, I use a 4x8 trailer to haul my Harley Sportster on with no problems. The total amount of weight is the one thing you have to worry about. My 't' weighs 2000# alone and the bike and trailer weighs 900# together. No problem stopping. You could add an electronic brake controller if the trailer has brakes and you exceed more than half the weight of the car. I made my hitch to bolt to the rear of frame under the bed using 4 grade 8 ,1/2 bolts. I think I saw the plans on the NTBA tech. pages. I did not use any brackets to keep the hitch from rotating forwards or backwards as this way I can take the hitch off and no evidence of it being there. There are two down tubes and a cross tube at the bottom with the reciever attached, all made from 2" square stainless steel. All this depends on the height of your "T" and the traier tounge. Hope this helps you and wish I could show you a diagram or picture.If I need a trailer. Looks like uhaul isn't going to rent it to me for a T-Bucket anyways.
If I was to buy a trailer. Would 4' x 8' trailer with maybe 2 to 4 foot sides be ok on a T?
I bought one of those trailers back in the mid 90's and my son has it now. It made several trips from northeast Ohio to Orlando and it tows great. However, I did not tow it with a T.Thank you.
I'm thinking of ordering one of these.
http://www.harborfreight.com/950-lb...ailer-with-8-inch-wheels-and-tires-42709.html
As long as you do not over load those SUPER- O 2 thin material frames, you should be OK... If you do buy one, check out all the mounting points, and re enforce all that could be pulled out of that thin material because of bad design and leverage to/on the brackets... You can not build that trailer for that money yourself, in this Country that is... hehe Remember this, the rule is to keep the top of the trailer ball at 16 inches high... Most all trailers are built with that as a correct height...![]()
I might think about replacing all of the fasteners with quality fasteners.
Mark
One facet of small trailers that needs to be addressed is rim diameter. In addition to a reduced load capacity, a smaller diameter wheel and tire combination generates much more heat on the tires and wheel bearings. This can result in tire and or bearing failures, especially at higher speeds on long trips in hot weather . Another is the use of trailer tires requires higher tire pressure due to their design which can cause trailer bounce on rough road surfaces especially with small diameter tires and light loads.If I need a trailer. Looks like uhaul isn't going to rent it to me for a T-Bucket anyways.
Whats the max size trailer I can tow with a T?
Could I get away with the 4' x 8' cargo trailer from uhaul?
If I have to tow. Maybe change my springs back to the 165 rate.
