AltBantam
There is a lot of information on Watts Links online, even here. Some good. Some not so. I hope someone here can tell me if I am right or missing understanding.
I was planning on using a panhard bar to center my 4 link rear suspension. But it turns out I cannot put the bar where I wanted to place it and the tubing be longer than 33" from mount to mount. That comes up to .095" of side travel if the suspension travels the full 2.5" up or down. Looking around, I realized I have nearly enough material to building my own watts link. So here is my question. I have seen manufactures, (Ford, Dodge, etc) have the bar mounts above the bell crank, angled downwards. I have read many say keep the bars parallel to the rear axle/ground. It seems as long as the distance between the mounting points (A) for the tubes and the bell crank (B) is the same, it should not matter how high the mounts are mounted off the frame (See image below). Am I right or am I missing something? Thanks
