Welcome to Our Community
Sign Up
Dismiss Notice
A Bit More Progress
Discussion in 'Bodies' started by choppinczech, Feb 28, 2016.
  1. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    I gotta share this because it works so well and saves a ton of work.
    Masked off and body filler spread. I had masking tape around the outer perimeter.
    When the body filler firmed up a bit, I sliced through with a razor blade.
    And removed the door mask and filler together.
    This even leaves the body filler a bit proud so you can work it down. And I never once had to deal with filler getting into the gap.
  2. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,800
    1,306
    Gender:
    Male
    Occupation:
    retired.
    Pretty neat Choppinczech.
    choppinczech likes this.
  3. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,488
    745
    Gender:
    Male
    Occupation:
    Retired
    You do amazing work! It'll be a unique looking t bucket when you're done.
    choppinczech and rbsWELDER like this.
  4. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Hmmm. I keep eyeballing this Mazda in the parking lot at work. The color is Soul Red Crystal 46V.
    It's absolutely gorgeous in the sunlight. I might have to rethink the charcoal grey.
    I've heard that it's a tough color to spray though.
    rbsWELDER likes this.
  5. MMC757
    MMC757
    Expand Collapse
    Apr 28, 2021
    100
    51
    Gender:
    Male
    Occupation:
    I get paid for what I know
    Agreed, That is a beautiful red that Mazda is using right now. It would look stunning on your car too.
  6. Spanky
    Expand Collapse
    Jul 29, 2016
    3,020
    2,427
    Gender:
    Male
    I believe you're correct. Some of the new metallics require a deft touch with the spray gun, and can be a bitch to match if repairs are ever called for. But I expect that you're up to the challenge, so don't let me deter you!
  7. Hacker
    Hacker
    Expand Collapse
    Jun 10, 2019
    17
    6
    Gender:
    Male
    It is a 3 stage paint, probably the closest to a true Kandy color without going with House of Kolor. It is not that difficult to spray, just an extra step in the process
    It is definitely a beautiful color!
    lincolnuT likes this.
  8. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,791
    554
    Gender:
    Male
    Occupation:
    Retired
    For me it helps to thin the paint so that I am not applying a lot of color with each pass.
    fletcherson likes this.
  9. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    Nice. I found with reds, your base color of primer/sealer must be uniform and will affect the outcome. Talk to a trusted paint sales rep or experienced body shop painter to get suggestions before spraying it and potentially being disappointed.
  10. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,644
    600
    Gender:
    Male
    With all the curves on your car that red will be STUNNING.
    H of C Candy is not an easy job either. We used to spray horizontal and then vertical then at 45* each way to even out the potential patchiness. Five coats minimum of clear followed by hand flat and polish. The 'newer' water based paint I have no real experience of, but have been told they self level and rely on the top coat for a finish.. as above talk to a experienced guy.
    Of course you could always do the prep and have a body shop put on the color. An oven always helps and they would have one. With the cost of paint these days one mistake could cover the price of a shop doing it. I have no doubts about your capabilities, but I would not try to paint a car any more. Technology and equipment has moved on a lot in recent years and the cost of a good gun is not cheap.
    G
  11. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Agreed. I'm in no way set up to spray in my garage.
  12. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,488
    745
    Gender:
    Male
    Occupation:
    Retired
    What are the three steps, base coat, metal flake and clear coat?
  13. Hacker
    Hacker
    Expand Collapse
    Jun 10, 2019
    17
    6
    Gender:
    Male
    you have a #1 ground coat which is generally your metallic base color, then you have a #2 tinted clear/tinted binder coat which gives it the "candy" depth and then obviously you have #3 clear.
    Neshkoro likes this.
  14. SRM1952
    SRM1952
    Expand Collapse
    Jan 14, 2014
    58
    27
    Gender:
    Male
    That is the color of my bucket , I love it . It has almost a copper base coat and a clear red and clear . The copper shows up in the sun at just right angle . Have had a lot of positive feed back at shows .
  15. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    The next step was to get a consistent space all along the outer door sills. I'll use a 3/4" tall bulb seal on the doors later on.
    At the fronts and around the hinges it was much easier and cleaner to use some premade flat pieces.
    Some 3oz. mat made the rest of it pretty quick. I was able to use the doors to cut the needed shapes.
    The width varied. So I laid on layers of glass up to the marked tape edge.
  16. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    This 1/4" burr with a stop collar and washer is really helping to fine tune the depth.
  17. butch27
    butch27
    Expand Collapse
    Nov 5, 2007
    2,493
    188
    Gender:
    Male
    Occupation:
    Retired
    Great ideas always...
  18. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    Tedious... nice job!
  19. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Here's another way to apply body filler that saves a bunch of work.
    Instead of spreading it out and then sanding to get it flat or contoured, I use non-stick tape covered panels to cast it. I use either flat, curved or flexible material. Whatever can be covered with this VentureTape.
    I thin the body filler with polyester resin and mask off any surrounding area. Apply the filler to BOTH SURFACES. This is important or you'll get air bubbles.
    Letting the excess ooze out isn't a big deal if you've masked well.
    After a few minutes pop off the mold, carve off the ooze and remove the mask.
    In this photo the taped backer was about 3" X 12". The hinge was masked off along with the whole surrounding area. You can see in the photo the high and low spots I needed to take care of. If I had done this the regular way of spreading and sanding it would have taken a few applications, lots of time and lots of headache.
    It's still just applying body filler. But it's flat right from the get go. And it's a one time clean method.
    Wyo George, rbsWELDER, Spanky and 4 others like this.
  20. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Hey guys. The last mechanical thing I needed to do to these doors was to add some door checks. My doors are so long that there's a lot of leverage on the hinges when fully open.
    I used these Mazda 6 door checks and shaved off some of the humps so that the detents aren't so aggressive.
    And used some Jeep Cherokee pivot mounts.
    I mounted them the same way as the hinges with the hourglass holes.
    But this time I added some countersunk rivets also.
    All in all they came out pretty good.
Share This Page
SSL Certificate
