Welcome to Our Community
Sign Up
Dismiss Notice
A Bit More Progress
Discussion in 'Bodies' started by choppinczech, Feb 28, 2016.
  1. Spanky
    Expand Collapse
    Jul 29, 2016
    3,088
    2,529
    Gender:
    Male
    Another awesome detail. Chop . . . you are amazing!
    oscar1955 and choppinczech like this.
  2. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,647
    605
    Gender:
    Male
    :cool:
    choppinczech likes this.
  3. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    Nice.
  4. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    I'm finally on to the jambs and inside flanges on these doors.
    After making lengths of this...
    I cut them into a bunch of these.
    They're somewhat structural, but mostly a backer for an 1/8" more glass behind them.
    These 3/8" spacers set on the sills will leave a 1/4" gap when all said and done.
    With that all covered with tape I added 5 or 6 pieces at a time. For stuff like this you can't beat body filler for attachment.
    Then a skin of body filler and couple layers of 6oz. cloth.
    The vertical flanges will be done the same way and continue on from here.
    The whole thing will get a build up of 1/8" glass on the outer exposed side.
    These areas were pretty straight forward. The fronts of the doors are going to be a real challenge with the hinges and door check to work around.
  5. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,647
    605
    Gender:
    Male
    I meant to ask; hows the new house and area working out?
  6. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Pretty good. It gets a bit tight sometimes.
    I haven't installed them yet, but I got a wall mounted jackshaft type garage door opener to free up the space over the car. And an electric cable hoist to lift the body.
  7. rubicon
    rubicon
    Expand Collapse
    May 28, 2007
    859
    254
    Gender:
    Male
    I really enjoy following your build. if you made an instruction video of this build, you would sell a lot of them. Awesome work.
    rbsWELDER and choppinczech like this.
  8. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    I'm doing these areas of the door jambs separately. Here's the pockets for the door checks.
    And the upper hinges.
    And I ended up making molds for the door bottoms and lower inside flanges.
    Prepping all of this glass is a PITA. But it gives me way better results. Especially with this 3oz. mat. It's quite thick.
    Feathering the overlapping edges leaves it like this.
    Instead of a hard cut that leaves bridging, trapped air and too much build up.
  9. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,239
    1,197
    Gender:
    Male
    Occupation:
    Retired
    So informative. I’m having trouble understanding the method of feathering overlapping leaves. Can you elaborate please?
  10. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    No problem.
    So we're only talking about fiberglass mat here. Anything woven wouldn't use this.
    If using pieces of mat, the correct way is to tear it into pieces like this. It all blends together.
    Not cut like this. This leaves trapped air everywhere.
    So all that I'm doing is making a "torn" edge in a controlled way.
    The pieces are shaped per templates and given an oversized perimeter where overlapping is needed.
    I use a block with attached sandpaper and a file card over the edge of a table.
    It's a way of getting mat to stay into tight inside corners and to stay in place over radiuses.
    raidmagic, cooter, Spanky and 4 others like this.
  11. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,239
    1,197
    Gender:
    Male
    Occupation:
    Retired
    Ok thanks! The drawing with the tapers was throwing me. I think I can put that to work.
  12. AusBucket
    AusBucket
    Expand Collapse
    May 23, 2008
    417
    237
    Gender:
    Male
    Occupation:
    Photocopier Tech-Retired
    This project is just fascinating, great display of attention to detail and a tutorial thrown in. Amazing work.
  13. rubicon
    rubicon
    Expand Collapse
    May 28, 2007
    859
    254
    Gender:
    Male
    Great info thanks.
    fletcherson likes this.
  14. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,846
    1,353
    Gender:
    Male
    Occupation:
    retired.
    I love your tutorials Choppinczech.
    Snicklefritz likes this.
  15. raidmagic
    raidmagic
    Expand Collapse
    Sep 25, 2008
    360
    56
    Gender:
    Male
    You opinion please. To do the gap between the body and the bed would you use weave or chop mat?
    Screenshot_20220522-151445_Photos.jpg Screenshot_20220522-151441_Photos.jpg SmartSelect_20220522-151620_Photos.jpg
  16. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,803
    560
    Gender:
    Male
    Occupation:
    Retired
    Is the bed going to be removable?
  17. raidmagic
    raidmagic
    Expand Collapse
    Sep 25, 2008
    360
    56
    Gender:
    Male
    No
  18. Rip VW
    Rip VW
    Expand Collapse
    Apr 20, 2021
    152
    117
    Gender:
    Male
    Occupation:
    Retired
    I think I would go with the weave. If it is going to be visible the weave may require much less working to final stages. I dunno though could go either way.
    lincolnuT and raidmagic like this.
  19. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    I'm still here.
    I've been super focused on putting a vinyl planked floor in the whole downstairs. It all started out well enough. Then when I got my laser set up I found out how uneven the slab was. So after 30+ bags of leveler and some grinding down to the aggregate in places it's finally dead flat and level. I also found several places where my walls were bulging out. So I had to cut out the sheetrock, plane the studs and re-texture. I need the walls to be straight for new baseboard and wainscot. It's taking a long time to pull off cause I have to constantly move furniture around.
    rbsWELDER, Spanky and CheapT like this.
  20. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,933
    637
    Gender:
    Male
    Occupation:
    Retired
    Been missing your posts. 30 bags of leveler! I know they don't give that stuff away. I had to buy 2 30 pound bags and almost needed a loan.
    rbsWELDER likes this.
Share This Page
SSL Certificate
